1 members (RLB),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28231 03/15/2004 4:33 AM | Joined: Feb 2004 Posts: 18 Junior Member | | Junior Member Joined: Feb 2004 Posts: 18 | I have a 1953 3800 with 216 engine. I have not had this truck long, a couple weeks, it's all original. I have it running pretty good til the crud broke loose in the fuel tank.
I think the fuel supply line is above the height of the bowl. I'm I right on this?
I need to drain the float bowl to get rid of a load of water and poluted fuel. But if the supply is above the bowl then unscrewing the supply line does not drain the bowl.
How do I do this without dismanteling anything? Is there a screw or plug I am not seeing? Will it drain if I take the idle mixture screw all the way out?
Also what manufacture & model carb do I probably have? | | |
#28232 03/15/2004 5:06 AM | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | Welcome to the board and congrats on your "new" truck.
If the "stuff" from the tank has come loose, you really need to drain the tank and remove it from the truck for a proper cleaning and sealing. It isn't that difficult of a project. I used the POR-15 process on my '53 3100 tank and was very pleased with the results.
You should really take the carb off too, for a proper cleaning. These carbs are very simple to work on, You most likely have years of varnish and crud built up inside the carb diminishing it's performance. A kit wouldn't hurt either. Removing the carb is a straitforward job, takes about 5 minutes.
Your carb is most likely the dreaded Rochester model "B". You could also have a Carter YF model which was a popular aftermarket carb.
Hope this helps, Steve | | |
#28233 03/16/2004 1:35 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Rochester carbs do not have a bowl drain. You can remove the air horn and use a syringe or try to snake one in through the bowl vent right above the choke plate.
