| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28156 06/27/2003 2:17 PM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Ok, I've got a narrow passage on my 250 head for spark plugs. Q: Does anyone know of a 5/8ths nut plug that works on 250's? Or, a 13/16ths plug with a taller nut than the standard Champions? Thanks
35 + years of rollin' steel!
#28157 06/27/2003 6:30 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I'll bet you have a later year head (or engine). In 70 or thereabouts they switched to a taper seat 5/8" hex "peanut" plug. Can you see the taper seat in the head? Try plugs for a 70 (Champion RV-19YC). | | |
#28158 06/29/2003 12:20 AM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Chuck, Good call. They fit no problem. Now if I can just get that darn distributer in correctly. Thanks again.
