| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28126 07/15/2004 1:22 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | I think I know the answer to my question but I thought I'd ask anyway. I just rebuilt my Rochester B on my 1950. It runs great but leaks where the top half meets the bowl. From what I can tell in the postings, it is typically a warped housing. Can I put any kind of sealer on the gasket that might help (High Tack Red from Permatex...)?
Any other thoughts? Would it be better to get a Carter? If so, which one and is it a straight swap? | | |
#28127 07/15/2004 2:19 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Michael, My Rochester B has always leaked there too. Afterwhile I just figured it was the nature of the beast. Maybe I should look into this a little more carefully also.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#28128 07/15/2004 3:55 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Michael - You might try some Hylomar sealent by Permetex. It's real good stuff, it only takes a thin coat on the gasket. It's been working for me. Good Luck George | | |
#28129 07/15/2004 7:37 PM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | From Carter's ads in the early 50's:
"The ABC's of carburetion: Always Buy Carter!"
The Carter carbs are better, but there's nothing wrong with your Rochester. I've had some success draw-filing the tops of carburetors where the main body and the top meet, but it has to be done carefully. During a rebuild, take a big, flat file, and carefully dress the mating surfaces unti they fit flush and compress the gasket evenly at all points. Be sure and do a good cleanup to keep the file shavings from getting into passageways and clogging them. I really don't like sealers anywhere around a carburetor, or intake mainfold. There's just too much risk of getting it pulled into a vacuum passageway and ending up sealing off the wrong place! Jerry
#28130 07/16/2004 5:54 PM | Joined: May 2004 Posts: 30 Member | | Member Joined: May 2004 Posts: 30 | mine leaks there too, I ignore it and hope it goes away. I found a brand new rebuilt rochester in the junkyard that didn't even have a grease mark on it. I took off the 4 screws and the inside of the bowl was brand new looking. The gas inside was still good and smelled fresh. The side of the carb had a "rebuilt" sticker on it. I think the PO tried to get the truck running but gave up and junked it. Anyway's 16 dollars at pick and pull and I'm going to put it on if the leak persists on the original. If I try the filing method and it works I'll keep the other carb for a future two carb offy setup. | | |
