3 members (Dennys28, 87GN, 1 invisible), 113 guests, and 2 robots.
Topics128,059
Posts1,055,818
#28041 08/20/2003 3:38 AM
ok, i was under the 53 a couple days ago and upon closeer inspection i have found that the four speed in the truck isnt an sm420 like i assumed would be,
what else could it have been in 53 in the 6400 16,000GVW trucks ? it is cast iron case and it has at least one PTO because its a grain dump truck.
are no marking on the shift knob.
thanks for anything
Randy the easter wabbit !
-here to help fellow enthusiasts as best as possible grin
parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others,
#28042 08/20/2003 3:47 AM
From the factory only the SM420 was offered from my info.
There were aftermarket trannies, but I believe that they were all offered as a secondary transmission behind the SM420.
The PTO setup was generally a bolt-on to the side of the SM420. Are you sure the transmission is not just an SM420 with the PTO add on?
#28043 08/20/2003 3:56 AM
no, it just looks small compared to an actual sm420, the pto part is normal to me, the "420" isnt, hmm...
hmm..
thanks
#28044 08/20/2003 8:29 AM
The Sm-420 is actually a pretty small transmission. It is kind of tall and skinny. If you have reverse to the left and back, chances are that is what it is. If it has a reverse lockout lever then it is one of the earlier crashbox 4 speeds.
Paint & Body Shop moderator
#28045 08/20/2003 2:02 PM
Check out www.novak-adapt.com
go to top of page and click on "Knowledge base"
then scroll down to transmissions...they have
picture's of manual transmissions...good site.
1946 chevy 1/2 ton panel
1937 ford coupe
#28046 08/20/2003 6:02 PM
Quote
nice,
will have to look under the truck again, normally i can identify a 420 and definitely a 465, but this one under the truck looks like neither, maybe its cuz of the no ribs on case casting 47-53 style thats throwing me off.
it just looks way different than a 420 or even 465(of course) and reverse is on left like a 420 is supposed ot have, did any other 4 speed have left hand reverse ?
thanks
#28047 08/20/2003 10:44 PM
I got all kinds of pics on the SM-420 right here;
GMC Transmission Data
