| | | Forums66 Topics128,266 Posts1,058,367 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28031 11/17/2002 4:27 PM | Joined: Nov 2000 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2000 Posts: 21 | Replacing the lever shocks. Tube shocks has rings on each end. Since I am making the mounts I am thinking about mounting the shocks vertical instead of leaning them foreward like the factory. Seems like the shock would work better traveling up and down rather than in a foreward up and down motion. This is on my 48 half ton stock front axel.
1948 Chevy 5 window "6" powered
#28032 11/17/2002 7:18 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | Yes the shocks would work better vertical. But watch the travel. The PO of my truck put them in so that the shock bottoms before the rubber stop hits the axil. I've bent one set of shocks so far.
if it dosen't need fixed, break it
#28033 11/17/2002 7:33 PM | | Anonymous Unregistered | | Anonymous Unregistered | Actually, tilted slightly forward allows the most dampening effort to occur at the unsprung location where it will do the most good. You don't need dampening at the extreme compressed condition. Those engineers back in the 40's and 50's knew from experience that the shocks worked best when tilted at an oblique angle to the axel travel direction. Vehicles today that have shock displacement parallel to axle travel use linearly varying damping rates to accomplish the same thing. Hope this helps. | | |
#28034 11/18/2002 5:38 AM | Joined: Sep 2001 Posts: 109 Member | | Member Joined: Sep 2001 Posts: 109 | Theory has it that shocks are mounted at angles of travel to eliminate harmonic vibrations from out of balance tires. Seems to make sense to me. You know, you can get those GM type stud mounts at most parts stores....... don't just rig a bolt and washer deal together!
John Kennedy 1950 Suburban street rod Pics in the Gallery....... new site up! http://home.joimail.com/~kennedyjp/
