| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27898 03/31/2004 4:48 AM | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Is there an easier way to check for oil pressure than pulling the valve cover to see if it's sqirting out? My idiot light won't go off. :confused:
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | |
#27899 03/31/2004 5:01 AM | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | Probably get an oil pressure guage from the parts place and hook it up temporarly (or mount it under the dash permently). Unless you want to loosen the sending unit real loose and put a bucket under and crank engine-turn off before you pump your pan dry. Maybe someone else has a way.
Truck Tinker from Talking Rock | | |
