4 members (Otto Skorzeny, Aggie49, baldeagle, Cosmo), 89 guests, and 5 robots.
Topics128,021
Posts1,055,346
Members48,420
#27879 02/11/2005 5:44 PM
My heat riser valve wasn't stuck, but it didn't have a spring. So, after purchasing one and installing it, the tension keeps the valve in the "heat off" position, meaning the exhaust is directed out the exhaust pipe and doesn't circulate to heat the carb and manifold.
It's my understanding that the goal of the riser spring is to keep the valve in the "heat on" position upon starting the engine and, once it and the heat riser spring warms up, the flap opens and exhaust is directed out the exhaust pipe.
However, my flap starts, and stays, in the "heat off" position. I've installed it exactly as pictured in the manual.
Any suggestions? Thanks.
#27880 02/11/2005 10:34 PM
Riding in the Passing Lane
Take it off & turn it over.
1972 Chevy c10 Cheyenne Super
#27881 02/11/2005 11:09 PM
Has anybody else done this, installed the spring opposite of the picture in the manual?
#27882 02/11/2005 11:11 PM
P.S. My initial post was incorrect...the spring holds the valve in the "heat on" position.
#27883 02/11/2005 11:18 PM
My bro & I both tried the way the manual shows, its wrong. I installed it opposite the manual(63 GM truck), now it works fine. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#27884 02/12/2005 12:50 AM
Actually, putting the spring on backwards wouldn't make any sense. By doing so, it would hold the valve in the "heat off" position when starting the truck...of course, it needs to be in the "heat on" postion at that point.
If the spring was installed backwards (contrary to the picture in the manual) the valve would never have a chance to close and heat up the intake manifold and carburetor.
#27885 02/12/2005 4:41 AM
All I know is I put it on opposite the manual pic(maybe the negative got reversed) & it is closed when cold, springs open under acceleration,& its open when warm. It should hold the counterweight up when the engine is cold. Brian
