3 members (Gdads51, 2 invisible), 60 guests, and 1 robot.
Topics128,115
Posts1,056,636
Members48,450
now this is just an observeation ive always had when looking at the chevy I6's intake/exhaust ports. Ive noticed that they only have two bolts that individually bolt to the block. the rest share one bolt for two sides. this seems to me like an unefficient form of keeping your manifolds tight and in place. am i right? anyone have good/bad input for me on this?
Manifold leakage and warpage is one of the many problems on Chevy sixes. It comes with having the intake and exhaust on the same side of the block, leaving nowhere to put enought bolts in to hold the manifold to the head. If you're having problems with leaking, smear a bead of ultracopper rtv on the gasket before assembling, and leaving it sit for 24 hours to cure before starting.
Fred
52 3600
69 C-10
