0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27838 02/14/2005 6:26 AM | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | now this is just an observeation ive always had when looking at the chevy I6's intake/exhaust ports. Ive noticed that they only have two bolts that individually bolt to the block. the rest share one bolt for two sides. this seems to me like an unefficient form of keeping your manifolds tight and in place. am i right? anyone have good/bad input for me on this? | | |
#27839 02/14/2005 8:20 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Manifold leakage and warpage is one of the many problems on Chevy sixes. It comes with having the intake and exhaust on the same side of the block, leaving nowhere to put enought bolts in to hold the manifold to the head. If you're having problems with leaking, smear a bead of ultracopper rtv on the gasket before assembling, and leaving it sit for 24 hours to cure before starting.
Fred 52 3600 69 C-10
