0 members (),
81
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27738 10/05/2002 6:59 AM | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | I have a 1962 chev 1/2 ton with stock 3.90 rear end gear ratio.(10 bolt) I want to switch it with another gear ratio so my 235 motor won't scream  down the road as much. What differnt ratios are available? Everyone tells me something different. :mad: I would like to get a used one if possible from what years and model cars or trucks will fit?!?!?! and where can i get new ones? :rolleyes: | | |
#27739 10/05/2002 7:34 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi PJ_STYLES, I too have a 62'C10, a friend of mine swapped his rear end for a 72'(5 bolt). He said it bolted right up with little to no modifying. Also here is a link, just type in your vin number, and everything from paint codes to rear end gear ratios.
Chevyboy62
My truck don't leak oil, it just marks its teritory.
#27740 10/05/2002 3:53 PM | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | Thanks for info chevboy62 i'll keep that in mind. But i really want to keep the 6 bolt rear axle i just want to switch gears in it. What gear ratios are available for 62's? and can i get them off any other vehicles?? from the 60's?? or do they just sell them new?  | | |
#27741 10/05/2002 6:17 PM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | There are some companies that sells the ring + pinion for the 10 bolt. On the 60-71' are all 6 lug, and 72' was the first year of 5 lug. The 60-72' has the same frame, coils + trailing arms in the rear. 1960-62 had torsion bar in the front suspension, and 63-72' had coils in front. These are the rear end ratios for 1962: 3.90:1, 3.38:1, 3.90:1(RPO), 3.38:1(RPO), and 4.11:1(RPO)
Chevyboy62
#27742 10/05/2002 8:39 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | On the chevy rear ends, (those ones in particular) the 5 or 6-lug rear axles should be able to be used in either rear end housing as long asthey have the same length and spline count.
