4 members (1955 1 Series, ShopRag, SNOYL, Southerntruck), 166 guests, and 2 robots.
Topics128,209
Posts1,057,461
Members48,471
Junior Member
Junior Member
I have a 1962 chev 1/2 ton with stock 3.90 rear end gear ratio.(10 bolt) I want to switch it with another gear ratio so my 235 motor won't scream eek down the road as much. What differnt ratios are available? Everyone tells me something different. :mad: I would like to get a used one if possible from what years and model cars or trucks will fit?!?!?! and where can i get new ones? :rolleyes:
*under construction* 1962 Chev truck: Bagged & bodydropped, shaved, custom made clear tailights & roll pan, custom made aluminum parts.
http://www.geocities.com/philswebsite2003/
Hi PJ_STYLES,
I too have a 62'C10, a friend of mine swapped his rear end for a 72'(5 bolt). He said it bolted right up with little to no modifying. Also here is a link, just type in your vin number, and everything from paint codes to rear end gear ratios.
Chevyboy62
My truck don't leak oil, it just marks its teritory.
Junior Member
Junior Member
Thanks for info chevboy62 i'll keep that in mind. But i really want to keep the 6 bolt rear axle i just want to switch gears in it. What gear ratios are available for 62's? and can i get them off any other vehicles?? from the 60's?? or do they just sell them new? cool
There are some companies that sells the ring + pinion for the 10 bolt. On the 60-71' are all 6 lug, and 72' was the first year of 5 lug. The 60-72' has the same frame, coils + trailing arms in the rear. 1960-62 had torsion bar in the front suspension, and 63-72' had coils in front.
These are the rear end ratios for 1962:
3.90:1, 3.38:1, 3.90:1(RPO), 3.38:1(RPO), and 4.11:1(RPO)
Chevyboy62
On the chevy rear ends, (those ones in particular) the 5 or 6-lug rear axles should be able to be used in either rear end housing as long asthey have the same length and spline count.
