2 members (NJC, baldeagle),
57
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27706 11/25/2004 1:48 AM | Joined: Sep 2004 Posts: 117 Member | | Member Joined: Sep 2004 Posts: 117 | There are different vibrations..they tell me different things. A vibration felt in the seat or that puts your feet to sleep is driveline..or something spinning fast. If the steering wheel shakes it is usually a tire balance problem. I know I am just a Jr. member,but I am a retired ASE Master Tecnician. I made my living doing Alignments and tire balance. Thats why I suggested jacking up the rear and running up to whatever speed it vibrates at. If it does that eliminates the front end. next,remove the rear tires. If it still vibrates remove the brake drums. If it still vibrates,you can about bet on the driveshaft or a clutch dish that has came apart. Anyway, before you start buying parts, find the problem. | | |
#27707 11/25/2004 1:52 AM | Joined: Sep 2004 Posts: 117 Member | | Member Joined: Sep 2004 Posts: 117 | clutch disk,not dish.... also don't forget the harmonic balancer..the rubber could be dried out and slipped. | | |
