4 members (MikeE, klhansen, FAST55, 69Cuda), 121 guests, and 2 robots.
Topics128,050
Posts1,055,667
#2766 11/10/2002 4:21 AM
what is the best way to drain the entire cooling system, block and all, on a 235?
#2767 11/10/2002 5:50 AM
Get some radiator flush follow directions.drain the system by opening the draincock on the bottom of the radiator and the one on the side of the block(may have a plug in the place where a draincock can go). There should be one on each side of a V-type engine,but on your 235 it will be on the driver-side toward the rear of the engine.(you can install draincocks in the place you removed the plugs).
Put in some radiator sealer/conditioner and add 50/50 mix of antifreeze/water. cool
#2768 11/10/2002 4:15 PM
Usually that draincock on the block is plugged up. If so just remove the draincock and poke and prod the hole in the block with a small screwdriver till you get the coolant to flow out.
