| | | Forums66 Topics128,049 Posts1,055,701 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27611 10/27/2004 12:52 AM | Joined: Apr 2004 Posts: 3 Junior Member | | Junior Member Joined: Apr 2004 Posts: 3 | I have a 53 chevy 3100 and I want to swap out the rear end. It had a 12 bolt in it when I bought it, but I can't use it because it is worn out. What I need to know is what other cars/trucks had a rear end that will bolt up under there. I am using a T350 automatic trans, and have the RB's bolt on mustang II front end. Please help me out!!!
If at first you dont succeed, try a bigger hammer.
#27612 10/27/2004 2:52 AM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | Do you want to keep the six lugs or are you to change to five lug wheels? | | |
#27613 10/27/2004 5:18 AM | Joined: Nov 2003 Posts: 6 Junior Member | | Junior Member Joined: Nov 2003 Posts: 6 | I want to go with the same bolt pattern as the front, which is 5 X 4-3/4". I know that I can probably go with a rear end out of any chevy car that has that pattern but I want posi so does anyone know of a rear that will fit under there? | | |
#27614 10/27/2004 5:43 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | I have a 10 bolt limited slip rear end out of a 77 Camaro in the truck. The track is 1" wider than the front track. Camaro bolt pattern matches your front wheels.
Gord 1954 1/2 ton 235 4 speed
#27615 11/07/2004 7:02 AM | Joined: Nov 2003 Posts: 6 Junior Member | | Junior Member Joined: Nov 2003 Posts: 6 | Thanks a lot for your help I appreciate it | | |
#27616 11/07/2004 9:18 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have the rear from under a '73 Chevelle wagon under mine. The wagon had bigger brakes than the sedans, which I thought was a plus. Mine is not posi, but I've seen similar cars with posi rears, so I know they are out there.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
