1 members (Rusty Heaps),
114
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27560 01/29/2002 1:16 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | I have a TH350 with stock speedo gears(for 14" rims and street tires) I now have 15" rims and tall (29.5")tires. I heard that there are different speedo gears (the little one) that you can get that are actually color-coded. Has anyone heard of this? Seeems cheaper that buying an expensive adapter box. Right now my speedo reads about 15-25 mph slow.Anyone heard of these?? | | |
#27561 01/30/2002 3:55 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | A fellow told me one time that the speed-o-gear could be changed up or down within a certain limit. I can't verify this just heard about it. He said to go to dealer for gear.  | | |
#27562 01/30/2002 9:23 AM | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | It is very easy to change the gears. There are a wide range to chose from. Was it right before you changed tires. If so figure out the differents in tire higth. What percent taller did you go? If you know the percent, count the teeth on the gear and multiply by the tire percent.
I just changed gears in my Dodge. I went from 3.21 to 3.50, this is pretty close to a 10% increase. My speedometer gear was a 29 tooth, so to speed up the reading I had to go up to a 32 tooth. 29 to 32 is almost 10%, its now reads right again. This works just the same using tire higth.
Just go down to the local transmission shop, they should have the gears. The housing inwhich the gears fit is adjustable. You will have to turn it so the gears mesh. It should be numbered in groups or ranges of gear teeth. Joe | | |
#27563 01/30/2002 12:58 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Thanks! I'm going to check a local trans shop.I will post what I find out later.Even if I can get a set "closer" to what the gauge reads(mine says 40MPH @ 65MPH) The truck didn't have any gauges when I bought it,so I bought a used set and refurbished them. | | |
#27564 01/30/2002 8:58 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Before you do that, make sure your speedo cable is hooked up all the way. When I fixed mine it indicated just like that- about half speed- and after I tightened the transmission end up it fixed it. I rebuilt my speedo and put in a new cable just like you. It didn't work at all when I got it. Now it is spot on.
