3 members (Hotrod Lincoln, Otto Skorzeny, MNSmith), 77 guests, and 3 robots.
Topics128,087
Posts1,056,338
Members48,442
Well... 33 celcius today.
- My dogs tap dance on the hot asphalt.
- Breweries are operating at full tilt.
- Pools are overflowing with kids.
- Girls are dangerously under-dressed.
The truck shows NO sign of over-heating but my temp guage does NOT move? Suspect.
I read in the manual that it is an ether filled affair???
Is there a retrofit for a temp sending unit?
What is a bolter supposed to do?
whizzerick
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
"What is a bolter supposed to do?" grin
- keep the dog on the lawn
- drink til ya drop
- keep a good distance from those noisey pools
- wear sunglasses so the underdressed chicks can't tell yer leering
- get a dairy or candy thermometer, pop the rad cap when its up to temp, insert thermometer. if the cooling system is a-ok, and yu've got a thermostat, the temp gauge should stay stable once engine warmed up . . .
I have run my truck in 100 degree weather and the water temperature was rock steady at 180. I also tested my gauge with boiling water and it pegs like it should, so I suspect you are fine. The trucks really have a well designed cooling system.
Paint & Body Shop moderator
How come here in Northern California (100F/38C) I haven't noticed the same phenomenon?
- Dog won't leave the air conditioning register
- At work, can't drink
- Pool hasn't been dug in my back yard yet
- Girls? What, did they all go to the beach?
It never moves? When it's cold it should show ambient air temperature (33C) and when its running it should increase to running temp - maybe 80C - 90C?
If it doesn't move ever there's a problem. If it moves only when warming up - great!
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
The used gauge I got from Mothertrucker shows cold when I start up and gradually warms and stays in the middle. It was hot today when I went to Home Depot and it stays at the same temp no matter what.
The patina matched my gauges perfectly.
54 3100 with 235
62 flatbed dump C60 with 261
