1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
I'm moving forward with my plan for an LPG powered Stovebolt - my '55 1st series 3600 (3/4 ton) had a 250 engine which has been recently rebuilt, and I stopped at the point before I bought carbs and intake/exhaust to start a family... grin Now getting back to this project, and with gas prices above $2 a gallon - and California's SB 708 potentially reinstating smog for cars older than 30 years (though my '55 should still be exempt) - I thought I'd give this a try. Did some research, and here's the plan so far....
The truck will be LPG only, not a dual gas/LPG. It's difficult to get optimal mileage with a dual system, and filling stations in California are close enough that maybe a 300 mile range is sufficient. Shooting for about 20mpg.
Will be utilizing a dual intake with two Impco 425 "mixers" - carburetion not required as LPG is already converted to a gaseous state. These will be controlled by a closed-loop feedback system that monitors the O2 levels in the exhaust and adjusts the fuel-air mixture appropriately. With this kind of system the fuel mileage should be better than a carbureted gas system, but not quite as good as fuel injected. Close though!
The 250 head was mildly ported and polished, and will be exhausting through some nice cast iron manifolds. Two O2 sensors will be plugged into the exhaust pipes just south of the manifolds to measure and control the fuel mixture.
One of the problems on a gas engine using these manifolds is the lack of exhaust heat to the carbs - with LPG this is not a problem! So no manifold heat plate required. [Back in high school I had a combo LPG/gas pickem-up-truck and on cold days it'd take several minutes to start on gas. With LPG it'd start up and run smooth immediately.]
However - the regulator/vaporizer which lets the liquid LPG expand into gas gets very cold, and can freeze up as moisture condenses and solidifies. To avoid this a hot water circuit is run to this unit to keep it warmed.
The remaining pieces then are the fuel tank and a fuel lockoff wired to the key. The fuel tank will go under the bed between the frame rails, probably 2 small long tanks straddling the driveshaft. Since it's a 3/4 ton the 2 piece driveshaft is carried in the middle and has little chance of becoming a projectile and puncturing a tank. I may decide to add another guard around the tailshaft end to prevent any escape of driveshaft problems.
Still working out if it's possible to run the filler up through the cab to use the standard filling location. Would probably have to weld an external filler pipe inside the cab to run the fill hose through, to prevent the possibility of LPG leaking into the cab.
The one "unknown" for me right now is the compression ratio. Using the standard 250 pistons it's pretty low (8:1?) - but LPG likes a higher ratio (13:1 to 14:1 optimal). I'm thinking to replace my pistons (unused - any takers?) with a higher compression piston to at least achieve 10:1 ratio. This should improve performance somewhat, but raise the cost.
That's about it for now - looking to spend about $1K on everything including the tank, which will probably have to be a used LPG tank to fit this budget. But over the next 2 years that should balance out the difference between gas and LPG, even considering the potential reduced fuel mileage.
Looking to finish up by fall. Keep ya posted!
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
Sounds like a good plan so far; definately keep up posted on progress and keep a list of part numbers for Tech Tips! wink
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
Anonymous
Unregistered
Anonymous
Unregistered
Hi compression pistons won't be cheap. I got 9.5:1 pistons for a 292 from Ross - don't remember what they cost, but seems like they were about $100 each. Not sure how much you could gain from simply decking the block and milling the head. Sounds like a fun project.
I have heard rumors that Chevy 307 V-8 pistons have the same dimensions as the 250 but would provide higher compression. They would need to be machined to remove part of the skirt to clear the rods. Might be a more inexpensive way to go...investigating!
-Boyo
I have heard that LPG pistons for the L22 Chevy engines are available, with about a 9:1 ratio. I have read about several gas engines using them for higher compression over at Inliners.
1954 GMC De Luxe COE
Boyo, I heard the 283-307 flat top piston story, plus the undished 230 pistons may work.Post on Inliners, quite a few L engine guys there.
Just check the pin height and pin diameter on those V8 pistons, they may work.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
Boyo, I kept the 292 out of my 63 3/4 truck with LP in mine, turboed. Then I started buying diesels. Many years ago (63 or 64) I drove an R 200 International tractor. I was a 3 axel but the rear axel was dead, except when you installed the belts. I never ran it with the belts installed. It was butane powered, single fuel set up. 501 inline 6, it ran good. I don't remember what kind of milage it got. We use an LP powered Chysler V8 (also single fuel) on a water pump at work. It runs 24/7 during the warm months. I don't recall how many hours it had on the last overhaul, a bunch. And it is clean at teardown. Make sure you have good seats and valves. I think you need to make sure the valves don't rotate. Good luck. Mike
I think I'd consider installing a turbo or supercharger. You could run your stock compression ratio and allow the boost to make up the difference. It is a little easier on the starter spinning over 8:1 rather than 13:1. I think the bearings would last longer as you would only be exerting a high load only at high boost pressures.
A turbo on LP would be sweet because the fuel is already a gas and you wouldn't have to worry about the fuel 'condensing' out through the turbo like you do with a gasoline unit. Just make sure you get a big enough convertor to vaporize all the fuel.
You might also be able to figure out a way to get compressed natural gas--or eek HYDROGEN eek
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
I worked at a shop with the Schwan's truck account. They're all LPgas. Factory stock small blocks, trick is to ADVANCE THE IGNITION TIMING. Schwans would supply a kit, which had the specs in it, I believe (and don't quote me) base timing is upped to 24 degrees. This is instead of any internal mods. When done right, horsepower is still decent and they run fine.
Don't forget to run your fuel lockout solenoid thru a simple alarm/killswitch ! wink
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
