| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27383 11/06/2004 11:05 PM | Joined: May 2003 Posts: 77 Member | | Member Joined: May 2003 Posts: 77 | I have a 71 C-10 that's been sitting for over a year while I've stripped down and restored the whole body. I did not touch the drivetrain because it ran and drove flawlessly. Today I decided to fire it up for the the first time in about 15 months. After changing the oil and priming the fuel system (which I completely drained), it fired right up and ran fine after blowing out a couple minutes of cobwebs!  So then I try t pulled it down into 1st gear (3 on the tree), but no dice! Thought the ole linkage was jammed but it wasn't. :confused: My thinking is the clutch disc somehow glued itself to the flywheel. Anybody ever have this problem? If so, any easy solutions without having to pull the whole tranny and clutch out? I've had several other manual trannied old vehicles that sat for extended periods of time and never before experienced this! Any help, guys?! :mad: & :confused:
Just trying to avoid the potholes on the road of life!
49 Chevy COE 55 Chevy pickup + way too many other project vehicles!
#27384 11/06/2004 11:23 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Yup
Block the front wheels....Jack up the rear and support the chassis well
NO CINDER BLOCKS!!!
Put the truck in gear.....Start the truck.....push the peddle in and out several times....Try to change gear.....if it grinds turn off the motor and repeat the first stuff......Push the clutch in an goose the motor a little Use the brakes a touch ...whatever feels like it's working This should free the plate......but It may not be good and need a new disc and flywheel surface anyway....
Good Luck | | |
#27385 11/06/2004 11:37 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | That happens to one of my trucks sometimes after a winter sleep.I don't jack it up,put the tranny in first gear,engage the starter,the truck moves a foot on the starter power, engine catches,you're motoring.Now just push the clutch to the floor and bump the throttle pedal until it frees.Some times ya need 3 feet, on on the gas, one on the clutch,one on the brake  . Of course the above won't work if the truck doesnt have free driving space. | | |
#27386 11/07/2004 12:50 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Please jack the truck up
I had a friend in Laguna Beach that did this the "Tony Way" The truck took off and pushed a car thru the rear of the garage and down a hill into PCH
This was not good | | |
#27387 11/07/2004 1:22 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Jim a man has got to be smarter than his truck  | | |
#27388 11/07/2004 1:36 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Your trying to entrap me aren't you
I'm really sorry your guy didn't win!!! But don't take it out on me Are you sayin' America wasn't smarter that your truck? | | |
#27389 11/07/2004 1:50 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Do I think my truck is smarter than America?Is that a trick question? | | |
#27390 11/07/2004 1:56 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | | | |
#27391 11/07/2004 3:39 PM | Joined: May 2003 Posts: 77 Member | | Member Joined: May 2003 Posts: 77 | Thanks for the suggestions, guys! Your friend must have been drunk? Don't know about that but when I finally got this truck to the point of being "done",after waaaaaay too much time trying to get around to finishing it, then this happened, I got drunk! By the way, this truck is neither from Texas nor Massachsetts! :rolleyes: In fact, I painted it blue AND gray! Actually, I think it came from Ohio, since there's somthing "stuck" on this machine! :p Since I can't recount anything like this happening late..ly, I think I'll name my truck Later..Nader!
#27392 11/07/2004 4:26 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The way ive always freed them up. Put the trans. in high gear. Prop the clutch pedal down or have someone sit in & hold it down. Push the truck back & forth. This will usually solve it.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#27393 11/07/2004 4:31 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Tony and Jim, I am not going to warn you guys again. NO POLITICS! :p
54 3100 with 235 62 flatbed dump C60 with 261
#27394 11/07/2004 9:04 PM | Joined: May 2003 Posts: 77 Member | | Member Joined: May 2003 Posts: 77 | Hey Wrenchbender, tried your method first and after several attempts it finally popped loose!  Took the truck out for a spin and everything works as flawlessly as it did when I last drove it!  Even had the wife take a couple pics of my ugly mug beside it. Ran the batteries dead in the camera though so I'll have to recharge them before I can download the photos!
