| | | Forums66 Topics128,180 Posts1,057,146 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27353 10/22/2003 4:21 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | Stock 235 - 1954 - Just Rebuilt and in place
I accidently dropped a washer (the distributor mounting washer - about 3/4" in diameter) into the distributor hole. Of course it dropped thru ALL the way when I tried to fish it out.
I assume it's resting happily in my oil pan. I believe it's a little to large to pass thru the oil plug hole.
Is this dangerous to leave in the engine? Should I put a strong magnet on the bottom of the oil pan to hold the washer (and other bits of metal) in place.
Thanks in advance! | | |
#27354 10/22/2003 4:31 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Gee, that is a tough one. I think it wouldn't do any damage. A magnetic drainplug is always a good idea.
54 3100 with 235 62 flatbed dump C60 with 261
#27355 10/22/2003 7:32 PM | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Believe or not my friend did the same thing, and we got it out with a flexable wire magnet. the sell them at sears I think or a hardware store. There about 18" long. GOOD LUCK. :rolleyes: | | |
#27356 10/22/2003 7:58 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | Originally posted by ol' 55: Believe or not my friend did the same thing, and we got it out with a flexable wire magnet. the sell them at sears I think or a hardware store. There about 18" long. GOOD LUCK. :rolleyes: Did he do this with a 235 engine? If so, where did he insert the magnet? I don't believe I could use the same hole it fell into. | | |
#27357 10/23/2003 3:08 AM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | For the cost of a new pan gasket, isn't it just a lot safer to drop the pan and fish out the washer? | | |
#27358 10/23/2003 4:48 AM | Joined: Oct 2003 Posts: 70 Member | | Member Joined: Oct 2003 Posts: 70 | tack weld a magnet to the pan on the outside | | |
#27359 10/23/2003 5:01 AM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | jgalt: I have to agree with OCK take the pan off fish it out and put the pan back with new gasket. Not that expensive will save a lot of worry and possibly heartbreak. popcorn The Truth is Out There (Put The Dist. mounting washer on before you put than pan back on) | | |
#27360 10/23/2003 2:19 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | I don't believe that I can drop the oil pan on the car (1954 BelAir 4-Door Car) without raising the engine quite a bit. There is a crossmember in the way.
I'm leaning toward a magnet on the oilpan as good insurance. | | |
#27361 10/23/2003 2:59 PM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | You need to get the washer out, one way or another.
When an engine is running, there is a hurricane of whirling oil and air in there, easily capable of spinning a washer around. The washer could nick flying rods, ping up cylider walls, get caught between a cam lobe and lifter, maybe even jam the disti drive gear.
And I'd bet it's a hardened washer. GET IT OUT! If the magnet works, great. If not, you will have to lift the motor and remove the pan. You might get away with just lifting it an inch or so and fishing in thru the gap.
Good luck! George | | |
#27362 10/23/2003 3:17 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Jgalt- Welcome Sedan-er. My stovebolt is the same as yours- '54 Bel-Air 4 door with 235 and three speed stick.
You can get the pan off without moving engine. However you have to unbolt the steering center link, and getting to the 3/4" bolt in the x member is somewhat difficult. Drop steering center link, unbolt pan and carefully finagle it out from around front x member and oil pump pickup.
But if the washer is laying flat on the pan floor, it shouldn't go anywhere. the trick is- are you sure its not in the way of anything?
If I may ask, where did the washer come from? I've never seen a washer as you describe on a 235. And believe me, I've looked. For about 6 months.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
