| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27286 02/20/2002 7:27 AM | Joined: Feb 2002 Posts: 2 Junior Member | | Junior Member Joined: Feb 2002 Posts: 2 | Some one gave me an old farm truck. I'm trying to figure out what engine it has. The stamping by the distributor is C2708I7334. There is a 350 emblem on the hood (1 ton?). It also has a two speed rear axle. any suggestions? | | |
#27287 02/20/2002 8:09 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Hi you have a 270 cid GMC motor! | | |
#27288 02/20/2002 8:39 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | That is a 2-ton truck, similar to a 6000 series in Chevy's. It is built with heavier components than the Chev in the springs, mounts and engine areas at least. The first three #'s are your engine size, a 270 in this case. The radiators are diff and heavier in GMC's too. Is your rear a one-line vacumm switch or electric? You probably have six-lug wheels and not 10-lug like Chevs? 20" tires? Your drivers door frame may have the plate with model and info about HP of engine, GVW and such. OR, maybe in glove box door. Shop manuals for GMC are available and go up to the 400 series in them. Get one if doing repairs, lots better than Chev books. :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
