7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny), 102 guests, and 3 robots.
Topics128,071
Posts1,055,901
Members48,429
#27286 02/20/2002 7:27 AM
Junior Member
Junior Member
Some one gave me an old farm truck. I'm trying to figure out what engine it has. The stamping by the distributor is C2708I7334. There is a 350 emblem on the hood (1 ton?). It also has a two speed rear axle. any suggestions?
#27287 02/20/2002 8:09 AM
Hi you have a 270 cid GMC motor!
#27288 02/20/2002 8:39 AM
That is a 2-ton truck, similar to a 6000 series in Chevy's. It is built with heavier components than the Chev in the springs, mounts and engine areas at least. The first three #'s are your engine size, a 270 in this case. The radiators are diff and heavier in GMC's too. Is your rear a one-line vacumm switch or electric? You probably have six-lug wheels and not 10-lug like Chevs? 20" tires? Your drivers door frame may have the plate with model and info about HP of engine, GVW and such. OR, maybe in glove box door. Shop manuals for GMC are available and go up to the 400 series in them. Get one if doing repairs, lots better than Chev books. :p
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
