| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27275 12/03/2001 12:39 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | What are good, later model donors for 60-66 model Chevy trucks? Which ones provide the easiest overall swaps (power steering, power brakes, disk brakes, etc.)?
-ftyler | | |
#27276 12/03/2001 4:57 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I beleive the 67-72 IFS will bolt into your frame and use same bolt holes and all. If you get the later (70's) of these, they have disc brakes. You can use the 73 up too but need to put 1/2" or so spacers betwwen the frame and IFS bolt on spots. I'm thinking holes for them are same too. I know a fella that has done this and working on it in his garage now. I saw it and it looked like "stock". He bought all new brake parts to use on his. I think once you get into around 63 and up, lots more stuff is "adaptable" then it was with earlier models with stovebolt engines and such.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#27277 12/04/2001 7:46 AM | Joined: Sep 2001 Posts: 6 Member | | Member Joined: Sep 2001 Posts: 6 | GL, Do you know if what you said about spacers would apply to putting a 74 1/2 ton IFS on a 58 frame? Is this possible?
Dave | | |
