5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#27147 01/14/2003 12:25 AM
Howdy,
Is the early chevy 6 lug pattern (40's) the same as current (90's,00's) chevy 6 lug trucks? are there any exceptions to the rule?
#27148 01/14/2003 3:32 AM
Yes, and also Nissan's. The differance may be in the backspacing and the bolt hole size. Early wheels have less backspacing and the modern wheels may rub on the tie rod ends.
Paint & Body Shop moderator
#27149 01/14/2003 5:56 PM
thanks!
#27150 01/15/2003 2:35 AM
Junior Member
Junior Member
I don't think they are the same?? I measured a 1997 GM 6 bolt truck rim and the bolt pattern was differnt. :confused: It was close but didn't measure the same. Also the centre hole was differnt as well. If anyone has put a newer 6 bolt rim on i would like to hear about it please. thanks smile
*under construction* 1962 Chev truck: Bagged & bodydropped, shaved, custom made clear tailights & roll pan, custom made aluminum parts.
http://www.geocities.com/philswebsite2003/
