5 members (Nick in Manitou, MickeyP, Jay R, MikeStone1953, 1 invisible), 134 guests, and 4 robots.
Topics128,026
Posts1,055,405
Members48,422
#26836 07/25/2002 1:00 AM
I'm nearing the point of bolting the head down on my 292. It's a non-integral type. As some of you know I purchased the 292 short block from an engine retailer in the Atlanta area. The block is the Mexican cast inline and (according to the casting #) is an '86.
What are the main bearing bolt and head bolt torque specs for the 292? Thanks!
#26837 07/25/2002 4:04 AM
Head bolts 95 ft-lb except left hand front bolt 85 ft-lb
Main bearing caps 65 ft-lb
Fred
52 3600
69 C-10
#26838 07/25/2002 4:07 AM
According to my 1966 Chevrolet truck Supplemental Manual, the main caps are torqued to 65 ft. lbs. The head bolts are torqued to 95 ft. lbs. A flywheel for a 292 is 65 ft. lbs while a torsional dampner is 60 ft. lbs.
Others jump in if this isn't right!!!!
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#26839 07/25/2002 7:22 PM
Thanks a lot guys!
While we're at it, what about the motor mounts, valve covers and intake bolts? That's it, I promise. :o
#26840 02/26/2006 3:28 AM
Junior Member
Junior Member
Ok but what order do i tighten the head bolts in
1961 c65 flat dump
1973 c50 flat bed
#26841 02/26/2006 4:37 PM
Riding in the Passing Lane
Start from the center 2& work out back & forth 2 at a time. Tighten them in about 3-4 phrases. Like 50#- 75#- 85# &95#. Like fred pointed out the latter specks call for 85 on the left front. They had some cracking problems in that area & revised the specks.
1972 Chevy c10 Cheyenne Super
