| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26836 07/25/2002 1:00 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | I'm nearing the point of bolting the head down on my 292. It's a non-integral type. As some of you know I purchased the 292 short block from an engine retailer in the Atlanta area. The block is the Mexican cast inline and (according to the casting #) is an '86.
What are the main bearing bolt and head bolt torque specs for the 292? Thanks! | | |
#26837 07/25/2002 4:04 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Head bolts 95 ft-lb except left hand front bolt 85 ft-lb
Main bearing caps 65 ft-lb
Fred 52 3600 69 C-10
#26838 07/25/2002 4:07 AM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | According to my 1966 Chevrolet truck Supplemental Manual, the main caps are torqued to 65 ft. lbs. The head bolts are torqued to 95 ft. lbs. A flywheel for a 292 is 65 ft. lbs while a torsional dampner is 60 ft. lbs.
Others jump in if this isn't right!!!! | | |
#26839 07/25/2002 7:22 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Thanks a lot guys!
While we're at it, what about the motor mounts, valve covers and intake bolts? That's it, I promise. :o | | |
#26840 02/26/2006 3:28 AM | Joined: Oct 2005 Posts: 9 Junior Member | | Junior Member Joined: Oct 2005 Posts: 9 | Ok but what order do i tighten the head bolts in
1961 c65 flat dump 1973 c50 flat bed
#26841 02/26/2006 4:37 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Start from the center 2& work out back & forth 2 at a time. Tighten them in about 3-4 phrases. Like 50#- 75#- 85# &95#. Like fred pointed out the latter specks call for 85 on the left front. They had some cracking problems in that area & revised the specks. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
