0 members (),
120
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26762 04/12/2004 3:29 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I have a 1953 GMC and the existing emergency brake rod was bent and trapped between the cab and frame. Does anyone have a picture of this rod? Is it a straight rod or is there a bend in it? I appreciate any help so I can put it back together again.  | | |
#26763 04/13/2004 3:19 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | I don't have my 53 here yet, so I don't know for certain. Would the earlier ones be the same? Well at least this will bounce ya up to the top of the heap and maybe someone will notice and clue us both in. If the earlier ones are the same I can take one out of one of the pickups I have here and get you a picture so you can get your truck back on the road.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#26764 04/13/2004 3:39 AM | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | It is as straight as an arrow! | | |
#26765 04/13/2004 10:07 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Straight but it is mounted at an angle from the left front of the cab floor to the rear middle of the cab.
#26766 04/14/2004 3:06 AM | Joined: Apr 2004 Posts: 4 Junior Member | | Junior Member Joined: Apr 2004 Posts: 4 | HI Guy's Hate to disagree with the straight rod. But I just restored my 53 gmc awhile back. The emergency brake rod does have a slight bend. Service manual even shows the slight bend. Hope this helps. | | |
#26767 04/14/2004 1:52 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I appreciate all the replies. If anyone has a picture it would sure help  | | |
