8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible), 99 guests, and 7 robots.
Topics128,264
Posts1,058,358
Members48,485
#26740 08/25/2002 12:19 AM
Finally got the old 248 running again with the new 2 barrel carb and adapter from Stovebolt Engine Co. Worked fine for a couple days and then, just crusing down the street, (not pedal to the metal), it starts making a noise akin to an exhaust leak and it seems to loose some power. Checked it out and doesn't appear to be loosing any water but there is no compression in #4 and 5 so looks like I blew a head gasket. frown My question is, could that 2 barrel carb have somehow caused the problem or is it just a coincidence? Since there's lots of Stovebolts running around with 2 or 3 - 1 barrel carbs on an Offy manifold I don't see how my 2 barrel could have caused it? Also, since I'm not a professional mechanic, (I just play one on TV grin ), and I haven't torn it down to confirm the diagnosis yet, is there something else that might be responsable for this compression loss? Thanks in advance for the info/opinions!
#26741 08/25/2002 2:21 AM
I doubt if the carb had anything to do with it. More likely a combination of deterioration due to age and head bolts that loosened with time. Another possibility is a warped head.
Fred
52 3600
69 C-10
