9 members (Gib70, Gdads51, 78buckshot, Phak1, mo2cyl, Oldcaliforniakid, BC59, Wally / Montana, MickeyP), 81 guests, and 2 robots.
Topics128,049
Posts1,055,667
#26590 02/07/2005 10:28 PM
I recently bought the truck for $700. I pulled the engine and trany this weekend it is a 350 and 350 trany, I was told the engine and trany came from the same car a 1971 Chevelle. I got some numbers from the block which are T0S14CRE and 10R244467, the second set of numbers the "R" may be a "B". Where do you look for the numbers on the trany? If I can get some help IDing the engine and where to find the numbers on the trany I will be greatful. Thanks
Get busy liv'n or get busy die'n
#26591 02/10/2005 5:18 AM
Hello............Help!!!!!!!!!!!!!!!
#26592 02/10/2005 6:28 AM
You might want to do some searching on the web for these. Look for Chevelle sites because that's where someone will have listed the numbers you're looking for.
Its not that people here wouldn't help you if they knew, but people here are mostly interested in old trucks and only track non-truck info that relates directly to the modifications they have made on their own trucks...
