4 members (papas52, Shade Baby, 2 invisible),
91
Mod | | | Forums66 Topics128,087 Posts1,056,340 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26434 04/22/2003 2:49 AM | Joined: Apr 2000 Posts: 28 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 28 | I am in the process of installing a 235 in my 46 3/4 ton. i was planning on installing a later 4 speed out of a 1 ton (53) when i discovered that i had an enclosed driveline on the 4 speed i have in there now. Can i go to a open driveline? How difficult would this swap be? should i just resign to be a double clutcher? any help appreciated. Phil Faircloth 46 3/4 ton | | |
#26435 04/22/2003 7:52 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Phil,
Is your driveshaft enclosed all the way to the rear-end or is it a two piece shaft with the front portion enclosed and the rear portion open?
If the rear portion is open, then you should be able to adapt a two piece open shaft from a later Chevy pickup. Most competent automotive machine shops can shorten or retube shafts to change the length and ends as needed to fit your specific truck. Bigger cities usually have specialty driveline shops that can do the work also.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#26436 04/23/2003 8:01 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Tourque tube doesn't mean double clutching unless your tranny is worn out .
It's good excersize anyway :p
My old '46 had the original tranny and torque tube , it shifed just fine , only 1st. is non-synchro .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
