1 members (CATMAN), 158 guests, and 1 robot.
Topics128,162
Posts1,056,935
Members48,458
When removing the drivers side leaf spring is it necessary to unbolt the steering drag link or as long as I support under the axle I can leave it together?
We're lowering the front and are ready to remove the drivers side...
Thanks guys!
Jason
I didn't unbolt mine when I put in the mono leafs. So, I guess no, you don't have to.
54 3100 with 235
62 flatbed dump C60 with 261
It's a good time to change the kingpins while you have it out, though. They are much easier to press out when the axle is out of the truck. Also check the draglink ends and balls for wear, you can get some binding problems if they are no longer round.
Paint & Body Shop moderator
