| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26215 05/15/2005 1:20 AM | Joined: May 2005 Posts: 8 Junior Member | | Junior Member Joined: May 2005 Posts: 8 | this engine is supposed to be an 350 but im not sure about what it came out of casting #3970010 4 bolt main Stamping # v0302txb can anyone tell me anything
Even a broken clock is right twice a day
#26216 05/15/2005 5:34 AM | Joined: Nov 2001 Posts: 16 Junior Member | | Junior Member Joined: Nov 2001 Posts: 16 | Engine block casting 3970010 used on 350 blocks 1969-1979 in cars and trucks.
Engine ID code V0302tbx V- made in Flint 03- March 02- 2nd day of month tbx- engine code designating it was made in 1975, its a 350, 165 HP, 4 BBLS, used in C20-3500 trucks. | | |
#26217 05/15/2005 5:40 AM | Joined: May 2005 Posts: 8 Junior Member | | Junior Member Joined: May 2005 Posts: 8 | what or were did you get that info from what I was told is that it came from a nova 1970 ive been really curious abuot it before I get started on it
#26219 05/15/2005 1:39 PM | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | www.mortec.com is where I go to decode Chevy engine numbers.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
#26220 05/20/2005 3:46 AM | Joined: May 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 50 | The block would work for a 350, 327(Large journal), or a 302. It would depend on which crank and pistons you use, the rods are the same except for a 400 small block. Later
Dave
Even a blind squirrel gets a nut sometimes!
#26221 05/20/2005 7:53 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | My book says it is a 350 cu.in. truck motor.mfg.from 1975 to 1977. 165 HP.used in C-20 to 3500 series trucks.Should have a 4 bbl.carb.My book is Chevrolet Small-Block V/8 Guide.Hope this helps. | | |
