0 members (), 54 guests, and 2 robots.
Topics128,049
Posts1,055,743
#2601 07/21/2004 4:53 AM
* Offline
I have a 1955 1st 3100 1/2 235 solid lifter engine. All that I have read doesn't talk about valve adjustment after rebuild. How do you adjust the valves before first start up and then after warm up. Any help,thank you in advance.
#2602 07/21/2004 5:54 AM
According to Motors Truck Manual, the '55 235 settings are made with the engine at operating temp. Of course on a new engine you want them somewhat close before you start it. The settings are: intake, .006 hot, exhaust .016 hot.
I would set them a dab wider cold then recheck after warm up.
With engine in position to fire no. 1 cylinder the following valves can be set:
Exh. 1,3,5. ----------- Int. 1,2,4.
Then turn engine one complete revolution, which will bring no. 6 cylinder to firing position.
Set: exh. 2,4,6. ----------- int. 3,5,6.
