3 members (chevyb, Shade Baby, CuzzFuzz), 249 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
so im gonna attempt to rebuild a 292 to put into my truck, ive never rebuilt an engine before. is there a book or manual i can get that will take me step by step through the entire process? preferably a book that deals solely with the 292 or other chevy inlines....
Junior Member
Junior Member
Chevrolet Inline Six-Cylinder power manual by Leo Santucci.... a book with a wealth of info on rebuilding..... I bought mine on e-Bay, but I've seen them listed in the various Stovebolt related vendors... Published by California Bill's Automotive handbooks, cover price $19.95
Good Luck...
Btw... My 230 cid, I/6 has got to be the easiest engine I've ever worked on...
Later...
Pete in NE PA
1964 Cheverolet Carryall
1965 GMC 1/2 ton
Riding in the Passing Lane
Watch the wrist pins. It seems like when you clean
the varnish they wind up a little loose & you have
noises you never had before. smile
1972 Chevy c10 Cheyenne Super
Santucci's book is good, but it is not a rebuild manual. More of a how to hop up your engine book. Best book that I know of would be the factory overhaul manual.
Fred
52 3600
69 C-10
fred t:
thank you very much, i was thinking the exact same thing, i already have santucci's book and it tells nothing of rebuilding the motor. i will try to find a factory rebuild manual. thanks again
I don't know what year, but in the sixties Chevy split the factory manual into two books, the service manual, which covered all the basics, and the overhaul manual, which covered rebuilding things like engines, trannies, and such.
Fred
52 3600
69 C-10
thanks again fred t, ill take a look at the local library and see if they have it. if not can i order it from some where?
I just gt a free 292 myself and I look forward to overhauling it. Thanks for all the good info.
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
Murdoc, most of the on-line retailers sell reprints.
Ralph, I'm jealous. The 292 is in short supply around here, farmers used them for irrigation pump motors.
Fred
52 3600
69 C-10
Hi Fred,
I was also given a 250 a while back. I dont know yet what I am going to do with them. I have 235's in my pickups. I need to overhaul one of the 235's before I start spending money on the 292.
Ralph
48 Chevy 3600 w/235
The only motor I have rebuild was a 305. I didnt need a manual or anything to do it. I have torn down motors before, so I had a good idea of where things went, and how they worked. One thing you need to remeber though is if you plan on using the same pushrods, lifters, piston, and connecting rods, make sure you mark the way they came out. I was told that a piston has to go back in the same place and way it did as when it was in before, because each piston wears its own shape in each cylinder, same with the connecting rods, lifters, and pushrods.
I have never rebuilt an L6 before, so I dont know how much different it would be from a V8. But, later on I will be rebuilding the 235 in my 55.
Good luck with your rebuild!
- Shane
- Shane (ChevyToughRebel)
2 Trucks;
-1955 3/4 Ton Chevy
-1979 3/4 Ton Custom Deluxe 20 4x4
1955 Second Series 3600
GED = Git Er Done
