4 members (Joe H, Jon G, J Lucas, Phak1), 75 guests, and 3 robots.
Topics128,050
Posts1,055,646
#25896 11/30/2001 12:01 AM
Hello all. Can anyone give me a good baseline for setting the timing on a stock 350 with an automatic and an 600cfm edelbrock and a hei dist? I also need to know how to adjust the valves on this engine and they are hyd.What is the idle set at also? How much oil pressure should I have? The engine is out of a car but is in a 64 truck now, its a 350/300hp.One more thing,is there a modulator valve that is adjustable so that it can be adjusted so the trans does'nt shift so soon? Thanks for any help on this guys,Philip
Philip Bland
1961 Chevy Apache C-10 Shortbed Stepside
235 ci
1964 Chevy C-10 Custom Shortbed Fleetside 350ci
Bedford,Ky
#25897 11/30/2001 5:02 PM
Well, at the risk of being kicked off the board, I will confess that my 50 gmc now has a 350 with HEI and 600 cfm carb. Funny how so many of us thought the same thing was cool. I woulda rebuilt my 228 in-liner if the block hadn't been cracked. I did a fair amount of research/tinkering when I first fired my 350 to figure out what to set the timing, since I put in a mild cam, it was necessary to move the timing to around 14 degrees advance. I think the factory spec was 8 degrees, and it would barely run. Good luck on yer truck.
#25898 11/30/2001 7:09 PM
Most aftermarket trans vacuum modulators are adjustable with a small screw in the vacuum port. I forget which way to turn it for later shift, but there should be instructions with it.
#25899 11/30/2001 11:08 PM
thanks guys, would also like to know what the total advance is set at.I think I'm asking this question the correct way?
Philip Bland
235 ci
Bedford,Ky
#25900 11/30/2001 11:39 PM
36 deg at 3200 rpm, that's what my '75 chev 350 runs, 8 deg at idle
Yes, officer it's licensed.
