| | | Forums66 Topics128,053 Posts1,055,777 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25854 12/05/2002 1:43 AM | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | I would like to use a hydraulic-activated clutch on my next project. I heard that in the late 50's Chevy trucks used hydraulic-activated clutches, is this correct? | | |
#25855 12/05/2002 8:17 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The bellhousing for a '61-'62 truck or suburban with a 235 or 261 will fit, they had hydraulic clutches with the slave cylinder on the passenger side. You will need to modify the frame to use the '55- up rear mounts, if necessary, though.
