1 members (JW51), 151 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#25775 09/05/2004 3:25 AM
Junior Member
Junior Member
I'm restoring a 46 pickup from SD. The gas tank is full of crud dust rust sticks etc. I put a handfull of gravel in it and then agitated it a bit. The inside part that I can see looks okay but ther are baffles that keep me from seeing the whole inside. It has a few pinholes now which I hope can be patched somehow. Maybe with epoxy. I went to the show in Auburn Indiana this weekend and bought some gas tank etch and some sealer from a company called "Bill Hirsch"
Before I go and use this stuff, does anyone have advise for me?
#25776 09/05/2004 3:36 AM
I think the local known reliable radiator shop is the first stop. They can do a better job of cleaning it than you can at home. They deal with the toxic chemicals used to clean it. Cleaning, and lining the tank with sealer should be $80-100.
New fuel lines from tank to the carb, and a new fuel filter at the carb would give you the best performance and least headaches. wink
#25777 09/05/2004 8:37 AM
if your going to keep that truck buy a new tank or have one made from aluimum junk the tank and the whorthless sealers you will be glad you went with a new tank for 200. instead of spending 100. and having problems shortly 2 cents
