7 members (Otto Skorzeny, 55shaker, joe apple, Gray_Ghost, Hush, 52Carl, JW51),
155
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25775 09/05/2004 3:25 AM | Joined: Dec 2003 Posts: 11 Junior Member | | Junior Member Joined: Dec 2003 Posts: 11 | I'm restoring a 46 pickup from SD. The gas tank is full of crud dust rust sticks etc. I put a handfull of gravel in it and then agitated it a bit. The inside part that I can see looks okay but ther are baffles that keep me from seeing the whole inside. It has a few pinholes now which I hope can be patched somehow. Maybe with epoxy. I went to the show in Auburn Indiana this weekend and bought some gas tank etch and some sealer from a company called "Bill Hirsch" Before I go and use this stuff, does anyone have advise for me? Thanks | | |
#25776 09/05/2004 3:36 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I think the local known reliable radiator shop is the first stop. They can do a better job of cleaning it than you can at home. They deal with the toxic chemicals used to clean it. Cleaning, and lining the tank with sealer should be $80-100. New fuel lines from tank to the carb, and a new fuel filter at the carb would give you the best performance and least headaches.  | | |
#25777 09/05/2004 8:37 AM | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | if your going to keep that truck buy a new tank or have one made from aluimum junk the tank and the whorthless sealers you will be glad you went with a new tank for 200. instead of spending 100. and having problems shortly 2 cents | | |
