0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25684 02/17/2003 5:47 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 |
#25685 02/17/2003 6:55 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | barely adequate for yer needs, right?  | | |
#25686 02/17/2003 10:40 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Might make those 10-ton hauls a little easier up the grades
#25687 02/17/2003 11:56 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Yeah, those Falconer racing engines are based on Chevy engines, primarily used in pylon aitcraft racing and in boats as an alternative to heavy and expensive dedicated V-12 aircraft engines. Here's a link to the site, don't all line up at once to buy one Falconer | | |
#25688 02/17/2003 6:41 PM | Joined: Jan 2003 Posts: 8 Member | | Member Joined: Jan 2003 Posts: 8 | Mechainiac, maybe you could just mount another stovebolt next to your existing one and get the same effect...  | | |
#25689 02/17/2003 8:20 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Don't you need two, one for the front and one for the back?
Fred 52 3600 69 C-10
#25690 02/17/2003 9:26 PM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 |
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#25691 02/17/2003 9:42 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Put that in a longbed AD and step on it and you have an instant shortbed...
54 3100 with 235 62 flatbed dump C60 with 261
#25692 02/17/2003 11:07 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Suuuure its chromed, but how reliable is the oil pump?
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#25693 02/18/2003 12:11 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | And for those of us without the $20-50K for one of these Falconer engines, may I suggest the Packard 4M marine engine used to power PT boats during WW2.These engines are sill available NOS for a measly 10 thousand bucks. V-12 | | |
#25694 02/18/2003 3:09 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Well, those packard engines would work but at 158 gallons per hour for one engine I think I will pass
#25695 02/18/2003 4:51 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | For those that missed it, My Classic Car had one of Jay Leno's cars this week, a 1915 Hispano-Suiza. Had an aircraft V8 in it, the one used in the Spad. 300+ hp and over 1,000 ft-lb of torque. The chassis would twist when he punched it driving down the street.
#25696 02/18/2003 4:20 PM | Joined: Sep 2000 Posts: 33 Member | | Member Joined: Sep 2000 Posts: 33 | Hey Luke, just get a 55 gal. drum and drive it 20 minutes at a time.  | | |
#25697 02/18/2003 7:49 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | I'm putting one of those V-12s into my Austin-Healey. 800HP, 2000lbs, I like them odds...
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#25698 02/18/2003 11:48 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Just in case 12 cylinders won't get the job done, maybe this 28 cylinder, 4600 cubic inch radial is for you.At wide open throttle ,gasoline engines use half a pound of fuel an hour per horsepower.... Imagine this thing in Chiphead\'s 50\'s Chevy car? | | |
#25699 02/19/2003 2:59 AM | Joined: Jan 2003 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 32 | I can't believe you guys are even looking at those ity bity motors. Check out this 42 cylinder water cooled monster. I don't think you could close the hood on this one. http://www.weakforcepress.com/ :p | | |
#25700 02/19/2003 4:12 AM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | Markw, the Tornado never flew. It was dropped before they got that far. It was built in sections. A few 14 cyl engines were built first. Then several 42 cyl versions were built and tested. It had the capability to go to 70 cyls. It had great throttle response and must have been a sweet runner, when everything worked right. Personally I doubt it would have ever made a good engine. Too many parts, the pumping losses had to be horrible, getting the right mixture through all that plumbing to all the cylinders. It had to be a nightmare to work on. But it is an interesting engine. It was kind of like 7 l6 engines sharing a common crank. Mike | | |
#25701 02/19/2003 6:48 AM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by Tony: Yeah, those Falconer racing engines are based on Chevy engines, primarily used in pylon aitcraft racing and in boats as an alternative to heavy and expensive dedicated V-12 aircraft engines. Here's a link to the site, don't all line up at once to buy one hahaha I just went to the site and listened to one of their engines. Find the line that says "Click here and listen for the thunder..." You should have seen my cats wake up and put their ears at full attention!!!
Then you will know the truth, and the truth will set you free.
- Jesus -
#25702 02/19/2003 7:31 AM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | One of these days, I'm going to learn how to cast an engine like these guys: http://www.acmefluid.com.au/larry/dmd1.html Except it'll be a V-12, built to accept off-the-shelf Chevy V-6 parts. If I could just figure out how to bolt two crankshafts end-to-end... Seriously, this is on my "to do" list for the next 5 years. And I wasn't kidding about the Healey... That unmistakable V-12 purr is something, ain't it? (I just played that audio clip for the missus - she said "That's pretty obnoxious." Cool!) -Boyo
#25703 02/19/2003 6:27 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Boyo, just build it to use an inline 6 crank and use special rods. Much easier.
