0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25650 12/09/2002 3:33 PM | Joined: May 2002 Posts: 14 Apprentice | | Apprentice Joined: May 2002 Posts: 14 | My 49 1/2-ton had a problem of popping out of 2nd every so often when the load was off. Suspected a synchro ring problem. At about the same time I had a problem with the clutch plate.
Took it in to have the clutch plate, springs, etc. replaced and while there had them pull the tranny. It was shopped out to look at the 2nd gear problem.
All back together, but the tranny guy could never get the parts (or so he said) and it went back in unfixed. Now I am having problems shifting from 1st to 2nd. I have to double-clutch to get it into 2nd. (Let up clutch while in neutral and then press again).
Sound like the guy finished off my synchro? Could it be the link adjustment? Any relation to the replaced clutch?
Poorer and frustrated... I think I went backwards on this deal. Any help would be appreciated.
Greg - 49 1/2 ton
#25651 12/11/2002 4:44 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Greg, is this a three-speed or a four speed??
#25652 12/12/2002 1:08 AM | Joined: May 2002 Posts: 14 Apprentice | | Apprentice Joined: May 2002 Posts: 14 | 3-speed... sorry for the slow response. I have been absorbed in jury duty for the last couple of days.
Greg - 49 1/2 ton
#25653 12/12/2002 2:09 AM | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | You are in luck I have a complete tranny that I just pulled from my 53 1/2 ton 5 Window. I think it is a 4 speed but I am not sure it could be a 3 speed I know it is stock 1/2 ton 53. It is the torque tube so it will bolt right in. I will even through in the fly wheel and clutch if you like! How does $50 plus shipping sound? It worked great but I upgraded to a Muncie sm-465 since I changed out the rear end and went with a open drive shaft. Let me know [email protected] is my adress and I live in Zip 68504
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
#25654 12/13/2002 2:23 PM | Joined: May 2002 Posts: 14 Apprentice | | Apprentice Joined: May 2002 Posts: 14 | Thanks for the offer, but for now I am going to take another shot at fixing my original.
BTW - my truck is back once again at the shop since the rear main seal they put in leaked! As they say... shoulda done it myself to begin with.
Greg - 49 1/2 ton
#25655 12/13/2002 2:43 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | question for zachscc? what problems if any and rear end did you use for your muncie sm465 swap and if you don't mind me ask, what kind of expense was it? I have a 4speed in a 52 five window, 235 with patricks 3:55, works ok but I run about 3,000 rpm at 60, this conversion kit from patricks, bot transmission and ring/pinion is suspose to equal a muncie and good for up to 300 hp motor, unknown is that is true, Thanks for your time.........Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
