1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25647 04/21/2005 9:22 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I finally got my act together and started. Tuesday I'm picking up a 292 with a granny 4. I have a 47 AD. Here are my questions:
1. Will I have to remount my radiator? 2. Should I take it to a rod shop to have the motor mounts redone so the clutch pedal lines up, or can I maybe trust a local "at my location" welder? 3. Assuming cost is not an option, would you all recommend a rear axle swap, or new gears from Patrick's?
As always, thanks in advance for any help.
jay
Your lack of preparation is not my emergency
#25648 04/22/2005 12:15 AM | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | you will probably get lots of feedback on this, but here's my .02. The 292 will require some special mounts. You COULD make them, but I suggest buying from Tom Langdon at the Stovebolt engine company. These are superior mounts and work perfectly. The 292 is long, so you will need to either move your radiator forward or modify the firewall slightly. I did the firewall modification, but others have moved the radiator. As for your clutch, this will probably require some fabrication to get the linkage right. I chose hanging pedals with hydraulic clutch, so can't give any advice on that part. Most folks are swapping the rearend or at least the gears to get better highway speed. There are several options for this.......just do a search of this site and you will get lots of info.
good luck
'53 chevy 3/4 ton
#25649 04/22/2005 2:13 AM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | On my current setup (under the grease and grime) it almost looks like the clutch pedal actuates a rod which goes directly to the clutch. Is the newer block/clutch compatible with this setup, if I'm right? Thanks,
jay
