| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25622 06/24/2004 2:34 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | Heard a funny noise driving to work today. The fan on the generator is making the noise. The fan will spin by itself with the pulley stationary. It is charging ok. I have another generator at home, so I can look tonight, but is the generator fan keyed to the shaft or the pulley, or how is it attached? I need to be able to drive home and don't want to lose a fan belt. | | |
#25623 06/24/2004 3:05 PM | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The pulley is keyed to the shaft, but the fan is driven only by friction. Check the pulley nut, and I'll bet you find it's loosened up a little. Tighten it before you drive anywhere, at least a little, or you're likely to lose the nut and lockwasher, and possibly the pulley. Jerry
