5 members (55shaker, Leo, 3B, Bill Hanlon, TooMany2count), 119 guests, and 2 robots.
Topics128,076
Posts1,056,280
Members48,441
#25618 01/31/2005 7:58 PM
I want to rebuild the 4 speed transmission out of my 70 Chevy 4X4. I can't get the front bearing out. In the book they show a special tool that clamps on to the bearing. Any ideas?
Riding in the Passing Lane
I,ve done a lot of them but it,s been along time ago. I take it you mean the lower roller bearing on the cluster. Some models had 2 grooves you could put screwdrivers in & pry it out. If not it seems I used to remove the snap ring that holds the rollers in & remove the rollers. That alowed the cluster to drop enough to dissasemble the trans. Then you can remove rest of the brg. & reasemble or replace it. They have a spacer that goes between 2 of the gears on the counter gear.A common problem is that 1 of the snap rings break & let the gear slide out of place. smile
1972 Chevy c10 Cheyenne Super
