2 members (Shaffer's1950, 1 invisible),
36
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25568 03/09/2003 5:34 AM | Joined: Mar 2003 Posts: 13 Member | | Member Joined: Mar 2003 Posts: 13 | Where can I find out about my plate, door ID. 20HP-L 1262
Looking for info Thanks | | |
#25569 03/09/2003 1:40 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | That VIN indicates a 1950 3100 series truck made in Van Nuys, CA. Also the 262nd one made that year at that factory. That is all the info a VIN gives. | | |
#25570 03/09/2003 5:03 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Brian, I believe you mean Los Angeles, not Van Nuys ? This is what I'm reading per Chevrolet's restoration booklet:
First digit = assy plant 20 = Los Angeles 2nd digit = year 1950 was designated by the letter H 3rd digit = series p = 3100 4th digit = Month of year mfg L = December The remaining numbers represent the production # 1262 one produced.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#25571 03/09/2003 8:58 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Actually, Van Nuys is pretty much a suburb or Los Angeles, so we are both correct, but GM's LA plant WAS in Van Nuys, opened in 1947, demolished in 1998. GM still has a presence there, I believe, a car-testing area. And the sequence numbers started with the digits "1001", making the vehicle in question number 262 produced. I know the restoration packets say Los Angeles, I would guess they considered the whole general area Los Angeles, as is frequently the case even now. | | |
