| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25474 08/15/2002 7:35 PM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | I am having my 235 rebuild on my 52 1/2tonner and am curious which tranny options I have for swapping. Ideally I want to hang on to the original 3-on-the-tree shifter assembly and my closed torque-tube driveshaft. I have Patrick's 3:55 rearend and read in the catalogue about the saginaw 4speed being ideal for my setup. Is there a tranny with overdrive, that I can use with my original shifter and driveline? I have also seen overdrive add-ons. Is there one that would fit my original 3speed? I am thinking of having the overdrive lever on the floor right next to the bench, maybe. Is something like that possible or is that just a dream of an eager to learn beginner at this? | | |
#25475 08/15/2002 8:25 PM | Joined: Dec 2001 Posts: 21 Apprentice | | Apprentice Joined: Dec 2001 Posts: 21 | Siegmund52,
You are pretty much limited to what you can do because of the "torque-tube driveshaft". I haven't of an "overdrive" unit for the 1/2T, 3Spd - 4Spd trucks running the torque-tube. If you go to an open driveshaft your combinations open up quite a bit.
64K10
64K10
#25476 08/16/2002 2:18 AM | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Thanks for the reminder. I am aware of the limitations. Just curious if anybody can provide a basic list of tranny models from memory about what can be used with or without open driveshaft on a 235 and 3:55 rear. Any hints? | | |
#25477 08/16/2002 5:00 AM | Joined: Dec 2001 Posts: 21 Apprentice | | Apprentice Joined: Dec 2001 Posts: 21 | Sieg...
Yep, it's limited, either the 3Spd or the 4Spd (SM420 with a very low 1st gear). The final drive is still 1:1.
64K10
