2 members (ronsway, Bill Hanlon), 106 guests, and 4 robots.
Topics128,172
Posts1,057,035
Members48,458
#25457 08/02/2002 11:23 PM
Help !!! Does anyone know what the parking brake rod (from the foot pedal to the swivel rod) looks like mine is gone. Is it a rod the can be purchased or do I have to make my own? I appreciate any help. :confused:
Which model of truck do you have?
#25459 08/03/2002 12:08 PM
This might help:
1950-1954 Park Brake
Series 100-250
[img]http://pstr-m03.ygpweb.aol.com/data2/006/47/BE/FD/7F/PXA2pkUZSNRFLlnioxFTEnSIHeMLWcR00180.jpg[/img]
OldCarKook, thanks for the picture, I can't read the part number but it's on the far right, the straight rod with the turn buckle. I'm not sure of the model number of the truck, no ID plates on it. It is a six lug wheel if that helps.
#25461 08/04/2002 11:06 AM
I am sure someone might email you with help finding the part you need cool
The parking rods are different from 1/2 to 3/4. (chevy) My 54-3/4 was longer than the 1/2 I bought from Carter's. I ended up going to a local welding shop and buying a 5/16 dia. rod, and threading the ends to accept the clevis. YOu will need to tack a washer or clip mid way to attach the spring.
Hope this helps.
Jim
Jim,
Thanks for the information. I'll try to determine what I need then attempt a go at it.
