| | | Forums66 Topics128,170 Posts1,057,033 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25457 08/02/2002 11:23 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Help !!! Does anyone know what the parking brake rod (from the foot pedal to the swivel rod) looks like mine is gone. Is it a rod the can be purchased or do I have to make my own? I appreciate any help. :confused: | | |
#25458 08/03/2002 7:30 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Which model of truck do you have?
#25459 08/03/2002 12:08 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | | | |
#25460 08/03/2002 2:26 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | OldCarKook, thanks for the picture, I can't read the part number but it's on the far right, the straight rod with the turn buckle. I'm not sure of the model number of the truck, no ID plates on it. It is a six lug wheel if that helps. | | |
#25461 08/04/2002 11:06 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I am sure someone might email you with help finding the part you need
#25462 08/05/2002 6:37 PM | Joined: Apr 2002 Posts: 15 Member | | Member Joined: Apr 2002 Posts: 15 | The parking rods are different from 1/2 to 3/4. (chevy) My 54-3/4 was longer than the 1/2 I bought from Carter's. I ended up going to a local welding shop and buying a 5/16 dia. rod, and threading the ends to accept the clevis. YOu will need to tack a washer or clip mid way to attach the spring.
Hope this helps.
Jim | | |
#25463 08/05/2002 7:26 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Jim,
Thanks for the information. I'll try to determine what I need then attempt a go at it. | | |
