1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#2532 05/21/2004 9:39 PM
Got my monoleafs for the front of my 51/3100, how about a few tips on installing them from you guys that have installed them on your own trucks. smile thanks old navy 51.................
#2533 05/23/2004 9:47 PM
Whats up out there ? I Thought a few of you guys have installed them your self. How about some help.old navy 51......................
#2534 05/23/2004 10:09 PM
What do you have questions about? It is pretty easy. Support the truck from falling on you, remove wheels, unbolt the shackles, let the spring swing down, remove rear spring bolt, and remove spring u-bolts to remove sprints. Reverse to reassemble. I'd recommend rebuilding the entire front end while you have it apart.
Jason
#2535 05/24/2004 3:24 AM
I put my front mono leafs on a few weeks ago. Jason is correct about the fact that it is unbolt then rebolt process. However, I can add one thing. I found that the spring eyes were just a little wide. In particular the spring eye that goes into the fixed spring mount; not the shackle end. So I had to get out the grinding wheel and shave it down just a little.
Jason also make a good point about rebuilding some of the front suspension. I found that my bushings were worn through and that the ball studs on the steering arms were showing significant signs of wear. So I have replaced all bushings on the frame. My monos came with bushings installes, so new ones there also. Then I bought new modern style tie rod ends. I bought a `53 drag link to get away from the ball studs. And then I drilled/pressed out the ball studs from the steering arms.
Definatly a lot of work, but I believe, well worth it.
David
#2536 05/24/2004 11:38 AM
You may find you need a good set of gas shocks in the front, the momoleaf has a lot less friction than the multileaf springs.
#2537 05/24/2004 9:25 PM
Thanks,guys,I just installed the new tie rod assy ,with the one inch dia tie rod also new cab mounts and new complete brake system with duel m/c. I also like the idea on changing to a 53 type drag link .
#2538 05/25/2004 3:45 AM
I'd been wondering about the '53 drag link. Glad to know it works.
Jason
