I've been working on two six lug disc brake kits. One came from the Buffalo, it is a bare bones kit with tiq welded caliper brackets from medium strength steel. It includes all the fasteners, the brackets, and 1/4 inch spacer plates to use with your stock hubs, rotors you find, and calipers you find. The rotors for his kit are from '71-'84 1/2 ton 4x4. Calipers are '77-'78 Chev 1/2 ton 4x4 or '71-'76 Chev Impala. You also need the hoses (Carquest SP6210 recommended.) When I bought my rotors, I found they did not have the three tapped holes for 3/8" machine screws needed to fasten the spacer plate to the stock hub and the rotor. After chewing over this situation and trying to find the drilled and tapped rotors, I decided to use some bicycle cone nuts with some 1/4" bolts so I could accurately hold the hub and rotor together to drive in the studs. Once I get three studs in, then I will drill three 5/16" holes in the rotors and use a tap to put the threads in. The spacer plate is very accurately fabricated and provides just enough clearance to allow for a little paint on the hubs. I used the electrolysis system to clean my old rusty hubs. They look pretty good now, but have not been painted yet.
I have not done much with the second kit from Classic Performance. The spacer plates will not fit the unpainted hubs and will need to be reamed. The rotors provided already have the tapped holes. I did notice the three countersunk holes in the spacer plates are a little big for the machine screws.
Taking the drums and hubs apart is not very hard. I used a brass pipe flattened a little to drive out the old bearing races. Then the hubs went through a hot tank degreaser and electrolysis derusting.
There is a lot of stuff to paint and clean. I also changed out the worn, tired tie rod with the butt weld on one end for a one inch extra heavy with modern ends from Classic Performance.
