5 members (Otto Skorzeny, 68ironhead, 32Fordpuchoptop, Guitplayer, greenie-reddy), 56 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
#25179 01/06/2005 6:03 AM
Junior Member
Junior Member
I am currently involved in swapping out a old tired 235ci with a 283ci. The 235 on my 58 had a wrist pin come out and catch the side of the cylinder. Total loss!! I located and bought a running 283 out of a 65 truck. I have started to install the 283 and have had to modify the bell housing. The next problem I foresee is the starter. The 283 has a modern starter and it looks as if I will have to install asimple starter circut/selenoid with a push button starter switch. I am not sure on the wiring and also I am using the generator from the 235 vice going to a altenato at this time. I will change later when I can use a complete wiring harness. Has anyone done this type of swap before and if so can you tell me the correct way to install the starter circut using the new seleniod?
#25180 01/06/2005 4:02 PM
Riding in the Passing Lane
Run a hot wire 12 gauge to one side of a push
button starter switch & run the other side to
the s term. on the selinoid. If you had afoot
starter on the 235 there should be a small wire
on the side of the switch on the starter. run
that to the I term on the selenoid. Or you can
change to a key turn ignition switch. The generator should work fine. Extend the wires
as needed. smile
1972 Chevy c10 Cheyenne Super
#25181 01/06/2005 7:13 PM
Junior Member
Junior Member
Thank You Wrenchbender, I will give that a try. I am not using the foot starter as the engine has a starter with it. I will run the wire to the small post on starter bendix. Thanks for the reply.
