7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25143 04/16/2005 2:27 AM | Joined: Nov 2004 Posts: 29 Apprentice | | Apprentice Joined: Nov 2004 Posts: 29 | Hey ive got a 261 in my 2ton. I also have a brand new 350 cfm holley 2bbl carb. Can i make this fit the stock manifold??? Does anyone make an adapter. Thanks For the help. Chris | | |
#25144 04/16/2005 5:38 AM | Joined: Feb 2004 Posts: 29,793 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,793 | There are some adapters available, but it's fairly simple to make one with a block of aluminum and a little machine work. We build custom adapters for that carb all the time for the roundtrack cars, since it's the only one the Nashville Fairgrounds track allows. Those are going on smallblock V-8 manifolds, however. It wouldn't be too difficult to make one for a 6-cylinder. Jerry
#25145 04/16/2005 11:52 AM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | You might check with Tom Langdon at Langdon's Stovebolt. He does sell some carb adapters. | | |
#25146 04/17/2005 11:11 PM | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | | | |
#25147 04/18/2005 7:51 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Clifford sells a manifold for that carb/engine combo. http://www.cliffordperformance.com
#25148 04/18/2005 11:15 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | No need to wonder, I do have a 350 Holley 2300 series carb on a 261 with a modified stock manifold.Forget the adapters,they mess up the mixture and limit the flow. 2300 Holley I enlarged the carb opening to an oval shape in a stock intake using common tools,had to weld up a few holes as the porting operation get into the exhaust heat riser part of the intake,I wanted to retain the heat riser for street use.Then made a carb mounting flange from phenolic cause I can work it wood working tools and it's a good heat insulator .Drilled and tapped a few holes to bolt the plate on,heli coiled the carb mounting bolt holes,made a cross over piece for the linkage. On my set up,the carb sits fuel bowl foward. The Holley on modified intake has great throttle response,more power and yes ,better fuel mileage than the stock carb or those ugly over rated Holley Weber 2 bbl carbs. | | |
